Lay person question about gongs
I have several steel ore crushers of different configurations and sizes, up to 1,300 pounds. When empty, sitting on the ground, they have a very nice ring to them when I hit them with a rail road tie or other large wooden object. They are like a giant bowl with a wide mouth and a small (six, eight or ten inches in diameter) hole in the bottom. I’m thinking about making some kind of artistic gong out of them.
Now, as a lay person, I assume that to achieve the best possible sound from these I would somehow magically suspend them in the air with no grounding. Since that is really kind of impossible, my questions are these:
What suspension material would be best? Wood, rubber, steel, etc.?
Would I want the smallest contact points possible between the crushers and the chosen suspension material?
Should they hang, like from a chain attached to the suspension material, or should they be fixed?
I appreciate any insight into these questions and any other comments you all might provide.
Thanks in advance.
Thanks in advance.
RE: Lay person question about gongs
(2B)+(2B)' ?
