Link lenghts from sketch to parameters
Hello all,
I have a big problem, I try to link automatically using macros constraints (Lenght for exemple) from sketchers to parameters. I renamed about 300 constraints (lenghts) using specifically names and I need to link them to paramaters using the same names.
My parameters should have the constraints name and value. Is this possible using macros?
Thank's in advance.
Thank's in advance.
RE: Link lenghts from sketch to parameters
Take a look here
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
CODE -->
Sub Link_Parameter_to_Dimension() Dim oPart As Part Set oPart = CATIA.ActiveDocument.Part Dim D1Name As Object Set D1Name = oPart.FindObjectByName("Diameter_1") Dim D1 As RealParam Set D1 = oPart.Parameters.CreateReal("D1", 2) Dim oRelations As Relations Set oRelations = oPart.Relations Dim Param As Parameters Set Param = oPart.Parameters.SubList(D1Name, True) Dim oFormula As Formula Set oFormula = oRelations.CreateFormula("", "", Param.Item(1), "(D1*1in )/2") End SubRE: Link lenghts from sketch to parameters
CODE -->
Sub Test() Set Document = CATIA.ActiveDocument Dim oPart As Part Set oPart = Document.Part Dim oBody As Body Set oBody = oPart.Bodies.Item("PartBody") Dim oSketch As Sketch Set oSketch = oBody.Sketches.Item("Sketch.1") Dim oConstraints As Constraints Set oConstraints = oSketch.Constraints For i = 1 To oConstraints.Count Set Cst = oConstraints.Item(i) If Cst.Type = catCstTypeDistance Then Dim sName As String sName = Cst.Name Dim Dime As Object Set Dime = Cst.Dimension Dim sParam As String sParam = Dime.Name Dim lValue As Double lValue = Dime.Value / 25.4 Link_Parameter_to_Dimension sName, sParam, lValue Else End If Next i End Sub Function Link_Parameter_to_Dimension(sName As String, sParam As String, lValue As Double) Dim oPart As Part Set oPart = CATIA.ActiveDocument.Part Dim D1Name As Object Set D1Name = oPart.FindObjectByName(sName) Dim D1 As RealParam Set D1 = oPart.Parameters.CreateReal(sName, lValue) Dim oRelations As Relations Set oRelations = oPart.Relations Dim Param As Parameters Set Param = oPart.Parameters.SubList(D1Name, True) Dim sBodyFormula As String If Right(sParam, 6) = "Radius" Then sBodyFormula = "(" & sName & "*1in)/2" Else sBodyFormula = "(" & sName & "*1in)" End If Dim oFormula As Formula Set oFormula = oRelations.CreateFormula("", "", Param.Item(1), sBodyFormula) End Function
