Procedure Qualification Record for Glued Joints
A Welding Procedure Specification (WPS) is a formal written document describing welding procedures, which provides direction to the welder or welding operators for making sound and quality production welds as per the code requirements . The purpose of the document is to guide welders to the accepted procedures so that repeatable and trusted welding techniques are used. A WPS is developed for each material alloy and for each welding type used. Specific codes and/or engineering societies are often the driving force behind the development of a company's WPS. A WPS is supported by a Procedure Qualification Record (PQR or WPQR). A PQR is a record of a test weld performed and tested (more rigorously) to ensure that the procedure will produce a good weld. (from WikipediaLink)
If there shall be a PQR to support a WPS, why not such a thing for glued joints (which normally are used to connect non-metallic pipes, such as GRP, together)?
RE: Procedure Qualification Record for Glued Joints
