Solid-Edge Models to UG CAM
We're considering a Solid-Edge (CAD) and UG CAM solution. Does anyone have any thoughts (experience) with this combination. We're also considering 'fully' integrated packages such as UG, Pro-E, and CATIA, and are wondering how the mixed Solid-Edge/UG solution is working for others.
RE: Solid-Edge Models to UG CAM
You can open a SE file in UG and a UG file in SE. All you get for each is a dumb solid, but you can choose to maintain the relationship. In other words, when the SE file is changed, the linked dumb solid in UG is updated with the changes and vice versa. Any features you add in either CAD package are only recognized in that CAD package, so you have to you have to work in the correct environment to make changes to the final configuration of the part.
The help file in SE has a lot of information on how to share the data between the two apps. Since you don't have SE or UG yet, I would ask your reseller for that information.
If I may ask, if you are looking into CATIA, why are you trying for a SE/UG mi?. Why not just UG?
--Scott
You should post this in the Unigraphics and Solid Edge forums instead.
Our major question is "How does the application of toolpaths vary in UG based on whether we're starting with a SE model or a UG model?".
