asme iii flange bolt loads
I am working on a flange design using asme iii appendix xi.
In order to calculate the required bolt torque I have assumed that the largest of either wm1 or wm2 gives the force value to use in the torque calculation?
The calculations are based on an existing flange design so the bolt size and quantity are given.
Therefore I think I don't need to calculate W?
Thanks in advance.
RE: asme iii flange bolt loads
[might want to post this in Nuclear]
Please go back and reread mandatory Appendix XI a bit more carefully, especially Section 3221 and 3223. I did not reach the same conclusion that you did.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
