"Zener" style check valve
Is anyone aware of a miniature check valve that has an adjustable breakdown pressure for reverse flow? By that, I mean a check valve that functions like a zener diode and would fit on .25" OD rubber/plastic tubing.
I've had no luck finding this amongst the small pneumatic equipment suppliers I'm used to dealing with.
Vidaman
Vidaman
RE: "Zener" style check valve
