Display "hidden text" from note on screen ?
Hi All,
I'm editing drawing templates... ( Yes, ...)
Since we run in "managed mode" almost all the text in the drawing heads are mapped to an attribute, similar to <W@DB_PART_NAME> and when the template is used it will display the Part name, " abcd1234" or whatever.
Now I need to verify templates which i have received and should be imported into Teamcenter, and then the attribute mapping needs to be correct.
Thereby i either need to do Information - Object on each text and in the listing window find the mapped attribute, or double click the text and read the string in the note editor. Neither method gives an overview when there are a number of texts to check.
Is it possible, with the help of VB or similar "print"/ "display" the "<W@attribute>" next to the text object ?
( Yes i know, i need to learn some programming...)
We run NX7.5 at the moment.
Tomas
RE: Display "hidden text" from note on screen ?
Are we talking about tabular notes, stand-alone note objects, or a mixture?
The code below will work with stand-alone note objects, it will create a temporary text object above the note that will show the first line of the text editor text. Is this similar to what you are looking for?
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        Dim workPart As Part = theSession.Parts.Work
        For Each myNote As Annotations.Note In workPart.Notes
            Dim myNoteBuilder As Annotations.DraftingNoteBuilder = workPart.Annotations.CreateDraftingNoteBuilder(myNote)
            Dim editorText() As String = myNoteBuilder.Text.GetEditorText
            Dim noteText() As String = myNote.GetText
            Dim textHt As Double = myNote.GetLetteringPreferences.GetGeneralText.Size
            Dim view_tag As Tag
            Dim textCoordinates(2) As Double
            textCoordinates(0) = myNote.AnnotationOrigin.X
            textCoordinates(1) = myNote.AnnotationOrigin.Y + textHt
            textCoordinates(2) = 0
            Dim textColor As UFObj.DispProps
            textColor.color = UFConstants.UF_OBJ_OLIVE
            theUfSession.Disp.DisplayTemporaryText(view_tag, UFDisp.ViewType.UseWorkView, text:=editorText(0), text_coord:=textCoordinates, ref_point:=UFDisp.TextRef.Middlecenter, color:=textColor, char_size:=textHt * 1.75, hardware:=1)
        Next
    End Sub
End Module
www.nxjournaling.com
Cowski my friend,
do i need to tell you that i love you ?
This is 99% exactly what i was looking for, if it would also include tables... 100% smile
Tomas
Quote (Toost)
do i need to tell you that i love you?
heartHappy Valentine's Day, Toost!heart
The code linked above should also handle tabular notes. I'd like to revisit the code to tighten it up, but it is a start.
