Different Component Name in Assembly
Maybe this is a silly question but I came across with this annoyance many times.
After an component replace some times it keeps previous component file name. I uploaded some screenshots were in the tooltip displays the previous component name, while the component is replaced with another.
RE: Different Component Name in Assembly
Preferences -> Assemblies...
...and check the option set for 'Descriptive Part Name Style'. If it's not set to 'File Name' change it so that it is and see if that helps.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It is set to 'File Name'. I figured out what I was doing wrong. When in 'replace component' dialog, I used to have 'maintain' name option instead of 'original', so it kept the previous component's name.
I think this is it.
Thank you again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
