extract a string
extract a string
extract a string
Hello world!
I want to extract a string from an other
for example dossier1\dossier2...\123-Mayrou\forum
for that I used SPLIT to extract "mayrou"
mayrou =Right(Split(productDocument1.Path,"\")(2),4)
Anybody please correct it.
Thanks in advance :)
RE: extract a string
I want to extract a string between two
...\Mayrou\...
Depending on what you want to extract (and which language are you using, for example is much easier in vb.net) it can be done in different ways
Bellow is an example using different functions (just to understand how is working),
CODE --> vbs
Dim MyString, TrimString, RightTrimString, FinalString
MyString = "dossier1\dossier2\123-Mayrou\forum"
MyStringNr = Len(MyString)
MsgBox MyStringNr
LeftTrimStringNr = InStr(MyString, "Mayrou")
MsgBox LeftTrimStringNr
RightTrimString=Right(MyString, MyStringNr - (LeftTrimStringNr-1))
MsgBox RightTrimString
FinalString = Left(RightTrimString,Len("Mayrou"))
MsgBox FinalString
or in your code
CODE --> vbs
Dim MyString, FinalString
strToExtract = "Mayrou"
FinalString = Right(Split(MyString, "\")(2),Len(strToExtract))
MsgBox FinalString
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
thx you Fernando :)
