Are ASME nameplates required to be visible at all times
I have a client that has some pressure vessels that have been insulated and the nameplate is not visible. He has some U-1 forms but we cannot match them with the vessels since we cannot see the nameplates. References to codes would be helpful.
RE: Are ASME nameplates required to be visible at all times
Refer to UG-119(a).
Quote:
Required nameplates shall be located in a conspicuous place on the vessel.
UG-119(f) also allows a "duplicate" nameplate to be installed on the jacket or other type of permanent attachement to the vessel.
