Adding assembly Contsraints Component color NX7.5
When I go to add an assembly constraint to my assembly (no sub assemblies in this assembly) NX turns my Components in the assembly to pastel colors. It Almost looks like there is a different work part in the assembly when I hit the assembly constraints. The constraints work ok and I can still select geometry to constrain. Nx is Just the turning of all of the components a diffetent color. Is there setting to turn this action off?
RE: Adding assembly Contsraints Component color NX7.5
A guy at work here found my issue. I had Emphasize Product interface Objects turned on under the Assembly Preferences.
