Fatigue analysis Nastran
HI,
does anyone know if is it possible to do Fatigue analysis due to temperature with Nastran?, I mean nodal temperature
thanks
RE: Fatigue analysis Nastran
Dear Luisa,
NX NASTRAN do not perform fatigue analysis, but you are lucky: winLIFE for FEMAP can do the job perfectly. You can perform fatigue analysis using stresses from any type of loading, including thermal stress. You can donwload a DEMO version of winLIFE, limited in model size, please visit http://www.iberisa.com/productos/winlife.htm or directly the developer in Germany http://www.stz-verkehr.de/e_index.htm
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
If you have access to MSC Nastran 2013 or higher versions, you can use Nastran Embedded Fatigue to run the stress analysis and the fatigue analysis in a single job. Otherwise, you need to run stress job in Nastran, and use a fatigue analysis tool to run the fatigue simulation.
