pls correct the code .macro for assembling bodies
Here is the script....its working...but if 3 bodies r there
then it is assembling 2nd body 2times and
not assembling the 3rd body. Anybody pls correct
the script. Thanks in advance...
Sub CATMain()
Dim partDocument1 As Document
On Error Resume Next
Set partDocument1 = CATIA.ActiveDocument
If Err.Number <> 0 Then
MsgBox "Open a CATPart first!!!", vbCritical, "Error"
Exit Sub
End If
Dim part1 As Part
Set part1 = partDocument1.Part
MsgBox "This macro is good only for a CATPart!!!", vbCritical, "Error"
Exit Sub
End If
Dim Bodies1 As Bodies
Set bodies1 = part1.Bodies
n = bodies1.Count
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")'The fisrt body of my CATPart
Dim shapeFactory1 As Factory
Set shapeFactory1 = part1.ShapeFactory
Dim i As Integer
For i = 2 To n
part1.InWorkObject = body1
Dim body2 As Body
Set body2 = bodies1.Item(i)
'~ MsgBox body2.Name
Dim assemble1 As Assemble
Set assemble1 = shapeFactory1.AddNewAssemble(body2)
Next
part1.UpdateObject assemble1
'~ MsgBox "Finish"
Part1.Update
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
viewer3D1.Reframe
Set body1 = Bodies1.Item("PartBody")
Part1.InWorkObject = Body1
End Sub
RE: pls correct the code .macro for assembling bodies
Thnk u ferdo....i tried with macro recording..It works for me...but actully what I want was with a loop.I will show the screen shots...
Bellow code is just recorded and cleaned a lit bit...I believe now is easier to create a loop for how many bodies you want. If you notice, you can create a separate function to insert and assemble a body then repeat how many times you want, what is bellow is inserting first all bodies then assemble them.
CODE --> catscript
Language="VBSCRIPT"
Sub CATMain()
Dim part1 As Part
Dim bodies1 As Bodies
Dim body1 As Body
Set body1 = bodies1.Add()
Dim body2 As Body
Set body2 = bodies1.Add()
Dim body3 As Body
Set body3 = bodies1.Add()
Dim body4 As Body
Set body4 = bodies1.Item("PartBody")
part1.InWorkObject = body4
Set assemble1 = shapeFactory1.AddNewAssemble(body1)
Dim assemble2 As Assemble
Set assemble2 = shapeFactory1.AddNewAssemble(body2)
Dim assemble3 As Assemble
Set assemble3 = shapeFactory1.AddNewAssemble(body3)
part1.Update
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
If you want in a loop then you can use something like this
CODE --> catscript
Language="VBSCRIPT"
Sub CATMain()
Dim part1 As Part
Dim body_main As Body
Set body_main = bodies1.Item("PartBody")
bodies_nr = InputBox("Write the number of bodies to be inserted and assembled", "Loop")
    For i = 1 To bodies_nr
        Dim body1 As Body
        part1.InWorkObject = body_main
    Next
part1.Update
End Sub
Fernando
