Instance Renaming Macro
I've searched the forums for macros that will rename instances within a CATProduct, but haven't had much luck in finding one that I think fits the bill for me.
What I want to do, is rename only the instances of the CATParts within a CATProduct.
{Tree}
Assembly.Catproduct
--ItemA (SHCS.45)
--ItemA (SHCS.47)
--ItemA (SHCS.78)
--ItemB (WASHER.54)
--ItemB (WASHER.22)
--ItemB (WASHER.63)
--ItemC (NUT.55)
--ItemC (NUT.62)
--ItemC (NUT.87)
What I want to do, is leave the part names alone and only renumber the instances. I want to change SHCS.45 to SHCS.1, SHCS.47 to SHCS.2, WASHER.54 to WASHER.1, WASHER.22 to WASHER.2, etc. etc.
I know there has to be a macro out there that will accomplish this, but I haven't had any luck in searching for one.
Any help will be appreciated.
Renaming the instances of 100+ washers isn't fun. tongue
RE: Instance Renaming Macro
CODE -->
Sub Rename_Products()
Dim x, y, z As Integer
x = 1
y = 1
z = 1
Dim objRootProductDoc As ProductDocument
Set objRootProductDoc = CATIA.ActiveDocument
Dim objProduct1 As Product
Set objProduct1 = objRootProductDoc.GetItem("Assembly")
Set objProduct1 = objProduct1.Products
For i = 1 To objProduct1.Products.Count
Set objProduct2 = objProduct1.Products.Item(i)
Select Case objProduct2.PartNumber
Case "ItemA"
objProduct2.Name = "SHCS." & x
x = x + 1
Case "ItemB"
objProduct2.Name = "WASHER." & y
y = y + 1
Case "ItemC"
objProduct2.Name = "NUT." & z
z = z + 1
End Select
Next i
End Sub
something to start..
