use spring or other connections(like axial connection) in variable directions
Dear all,
I want to create a spring connection between to points. but, spring works only in on direction (direct of line
between to point) .
when i stretch spring in other directions, it doesn't work and system get error.
do you know how can i use spring or other connections(like axial connection) in variable directions?
