Adding a pause to a journal for a Video
I tried to record some modeling operations in a journal with a pause
Tools / Journal / Record
Then
Tools / Journal / Insert / User Pause
The result code is
Dim theUI As UI = UI.GetUI()
theUI.JournalPause()
And the journal pause, but what's the code to wait some seconds ?
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Adding a pause to a journal for a Video
The JournalPause() method will pause execution by popping up a dialog box. The journal will suspend execution until you press OK on the dialog box. If you want to pause and restart after a specified amount of time, you can use the Thread.Sleep() method instead. Pass in the time (in milliseconds) to pause execution.
CODE
Option Strict Off
Imports System
Imports System.Threading
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        MsgBox("before pause")
        'pause for 5 seconds
        Thread.Sleep(5000)
        MsgBox("after pause")
    End Sub
End Module
www.nxjournaling.com
Hi Cowski
Thanks a lot, it works well
Is there a way to reduce the time to execute all the journal duration ?
Thanks in advance
Didier Psaltopoulos
If I understand the question correctly; for a shorter pause, pass in a smaller number (the number represents milliseconds to pause).
CODE
Thread.Sleep(n)
Hi Cowski,
I was not clear.
For example, If I record some sketch operations and add a pause, I can have the time to see the result
But I would like to reduce the speed to each operation.
Didier Psaltopoulos
So basically a "slow-motion" replay?
You might be able to do that with several sleep statements.
  1. run chunk of journal code
  2. update display
  3. sleep
  4. repeat
Ok Cowski
I will test and let you informed
Didier Psaltopoulos
It appears that what you're actually asking for is something that would be better accomplished by editing the resulting raw video file itself. With tools like TechSmith's video capture and editing tools, such as Camtasia Studio, you have the ability in post-production to expand and/or compress the apparent speed of the video when it's played-back. Perhaps it would be better to invest in this sort of video editing tool rather than trying to use a journal to FORCE NX to behave in a way where IT IS speeding-up and slowing-down just so that the video, when it's finally captured, will playback the way that you want it to. And if this is something that you will want to do in more than one instance, that investment in the video editing software may provide a very good return over the long haul.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Good point, that would certainly be easier. Windows includes "movie maker" software that may have the tools to do what you need (I have not used it).
Capturing the 'raw footage' is not the problem (we've even built that into NX), but rather it's the post-production that will need something more functionality. Certainly Camtasia Studio will do the job, but it's not inexpensive although probably worth serious consideration if this is something that you're wanting to do more than once or twice a year. Now you might be able to find some cheaper tools at there, perhaps even some decent shareware, but irregardless, whatever you find will probably be well worth doing since going the journal route is going to add a lot of complexity to the workflow particularly if it's needs to be repeatable.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have Camtasia and I agree with you. It's better to use it
Didier Psaltopoulos
