NX 8.5 revolve feature isn't working as expected
Hey Folks,
So I am relatively new to NX8.5, however I have been successfully able to make solid revolve features before.
I know it seems stupid trivial but for some reason NX isn't creating a solid shell for me when I try to revolve a somewhat large scale sketch.
Here is what NX is giving me when I try and revolve about the ZC axis:
My sketch is fully closed. Here are two close ups of the harder to see portions:
It is a very strange effect. If I accept the revolve like this and rotate, I get really weird effects:
Could someone help me out and explain to me what is going on here? I have made washer-shaped parts and just regular revolves. I don't understand why its doing this.
Thanks everyone!
-Ben
RE: NX 8.5 revolve feature isn't working as expected
If it is a large sketch, it may result in a solid that is outside the default view clipping planes. A view fit or update display usually takes care of this by adjusting the clipping planes to some value larger than your model. If these options don't work, look in Preferences -> visualization; there should be options to adjust the clipping planes manually if needed.
www.nxjournaling.com
last answer is right ur sketch is very big and ur actual model is solid only because of some graphic issue ur model seen like sheet. please select fit screen and check.
Easier fix for this is simply replace view, which re-creates clipping planes based on size of the model.
www.jcb.com
NX 7.5 with TC 8.3
ctrl+F and the part is adjusted to the window and you´ll see it as it should be
You people are G-ds.
ctrl-F worked!
Thanks so much
-Ben
or press the HOME key
Jerry; HOME does "somewhat" the trick but not ...
Home is default = Orient View to Trimetric AND Fit View.
- If you already have the Trimetric orientation then the "Fit" is all you see but...
I know, i am a Messerschmidt smile
Tomas
oh ok,
thanks for straightening me out
