Connect the models between them on each .C2 file
Hi.
I’m working on a pipeline line of 158 km…I need to cut the line in 10 km pieces, because CAESAR doesn’t run with more of 32000 nodes.
The thing is, How can I connect the models between them on each .C2 file?
Is it correct if I try to put anchors at the extreme of each model? Because if I use the displacement option on the buried pipeline, CAESAR doesn’t run (Error 57E).
Thank you for your attention.
RE: Connect the models between them on each .C2 file
Running Caesar end to end ... :-)
I hate Windowz 8!!!!
But, could you please explain me why should I model only the last 500 meters at each end of the pipeline and not all the pipeline?
Thank you.
You say only check out the last 500m at each end of the pipeline. It depends where the "virtual anchor" is located which depends on the soil properties etc etc. surely!!!!
you mean like this one?
http://www.saudiaramco.com/content/dam/Publication...
