carbon fibre analysis
I have to do a finite element analysis with ANSYS of a commercial carbon fibre tube. If have no information about the different layers of the tube.
All material properties I have are the following:
I assume that the material data I have to define in ansys is:
EX=2.5*10^6
EY=8.7*10^6
GXY=0.8*10^6
PRXY=0.43
Am I right?
But with these propertys I will only be able to do a 2-D analysis with plane elements. Will it provide me satisfactory results?
What data may I use, if I want to do an analysis with shell elements or volume elements?
I would be deeply grateful if you could give me any hints.
EX=2.5*10^6
EY=8.7*10^6
GXY=0.8*10^6
PRXY=0.43
Am I right?
RE: carbon fibre analysis
of course, you can make a whole mess of assumptions, but then you know what "assume" does ...
Quando Omni Flunkus Moritati
i think you can use this material for planar elements, which includes shells and plates, and also 3D (solid) elements ... why not?
And what parameters can I define for EZ, GYZ, GZX, PRYZ, PRXY if I use 3D elements?
if this is "real work" i'd suggest calibrating your model by testing. deflections are the easiest thing to measure.
Could you explain that more precisely?
Why use solid elements to model a tube? Unless its a thick wall, use a multi layer shell like SHELL281 and set up your ply data with the SECDATA cards. Also, I think you're need some data for the matrix. Also also, you might want to read up abit on composite materials. I took a class on plastics and we used Mechanical Properties of Solid Polymers by Ward and Sweeney. See chapter 8.
Rick Fischer
Principal Engineer
Argonne National Laboratory
