Harware (Standard parts) Implimenting in UG-NX integrated with TCE
Hi, I have to establish hardware (standard parts Bolts, nuts, Washer) library in Teamcenter. This will help to make it easier for the engineers to pick recommended hardware thereby increasing manufacturing and cost efficiencies. Is any suggestion or best practices on this?
RE: Harware (Standard parts) Implimenting in UG-NX integrated with TCE
I Downloaded Machinary library from GTAC. Now I need to edit to the specific part numbers and bringing in to TCE. which is the best practice to create library in TCE?
and also which is the preferable option part family or Knowledge re use to establish the library?
When I select the fastener to ‘Add to assembly’ it’s giving an error ‘the family members saving directory does not exist’ causing unable to load the part.
Also I have created the Child components from master file spreadsheet. How these child parts can be loaded in to the Reuse library? and user can pick it from the reuse navigator.
Find attached file.
