Designing Pressure Vessel for Deflagration
Have a pressure vessel to be designed per ASME Section VIII Divison 1 along with explosion containment. I see Nonmandatory Appendix H Guidance to Accommodate Loadings produced by Deflagration and it's reference to NFPA 69 chapter 5. Looks like NFPA 69 2008 Edition would be chapter 13. Appears the reference in Appendix H is out dated. Looking for info from someone with experience with similar design about how to apply Appendix H to the code calc's.
Looks like a MAWP is determined from NFPA 69 and then the code calc would have to say the design had a MAWP equal to or greater than the value from NFPA 69.
Dale
Dale
RE: Designing Pressure Vessel for Deflagration
"Whom the gods would destroy, they first make mad "
