Presence of H2S in oil sump for reciprocating compressors
dear all,
good day
we have three gas reciprocating compressors non lubricated cylinder. They have a lot of triple (damaging in piston rings, riders, stuffing box, valves and also vibrations)the back up N2 is not enough which it cause the H2S to escape to oil sump. after analysing the oil I found the presence of H2S in oil. THE TYPE OF OIL IS ACER 150 WHICH IS A MINARAL OIL .
my question is that lead to crack sulfide stress or is there any more problems could cause by this issue ??
good day
RE: Presence of H2S in oil sump for reciprocating compressors
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
please check the attachment for data sheet and oil analysing
what type of purge gas is run thru packing gland/distance piece
it is nitrogen
