Femap fatal error 9137
Dear all while run the analysis i get fatal error 9137. While discuss with siemence they give solution to modify coincident node.i got the solution.
but now i again get the problem, but i am not getting the solution
RE: Femap fatal error 9137
Plot here the output file *.F06 where the FATAL error appear.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
PARAM, BAILOUT, -1
This will force the analysis to continue despite the above mentioned error. Once the result is out you can check the deformation and you should be able to identify where the model was not constraint properly as the deformation would be abnormal. This is a very crude method but has worked well for me and hopefully it will for you also.
