Additives to Epoxy Based Inks to make surface hydrophobic
Hi i'm seeking advice on additives to epoxy based inks for silk screening.
What i'm trying to do is to create masks/patterns from epoxy inks. What i'm wondering is if there is any additives i could put into the epoxy based ink to make the surfaces hydrophobic/super hydrophobic in nature.
I've tried to add PTFE powders to the ink but it's not creating a good hydrophobic layer. Any suggestions or advice would be appreciated.
RE: Additives to Epoxy Based Inks to make surface hydrophobic
actually i've tried to powder the ptfe on top of the ink and yes it does work to a point but it'll cost me a lot in materials and its not the most efficient if i had to make a lot of masks/patterns.
But i'm actually looking at a parfin wax as an alternative, i'm also looking at silanes and siloxanes.
I could always silk screen regular epoxy resin, but i would have to play around with the viscosity, that's for sure!
