how to write a rule for this relation ?
Hi All
I have two parameters , one of the type angle 'c' , the other is length 'b', the base amount of b is 25 and for c is 360 degrees , they are related to eachother through a law
I want to write a rule to mention that :
if b > 25 then
c=360+f(b) some function of b
how do I write it in Rule base ?
thank you very much
if b > 25 then
thank you very much
RE: how to write a rule for this relation ?
if (b > 25)
{ a=2*PI+2*PI/25*(b-25)}
since a is angle and b is length , how should I write it ? ? 2*PI or 360 ?
/*Rule created by dbezaire 05/02/2014*/
let b (length)
let c (angle)
if b > 25mm
c=360deg+tanh(b/1)
/* the some function of b must return an angle! */
Win XP64
21SP7/22SP5, 3DVIA Composer 2013X, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
/*Rule created by Farzad 2/4/2014*/
let b (length)
let a (angle)
if b > 25mm
a=360deg +360deg/25mm*(b-25mm)
I saw somewhere that I have to use the {} and () does it make any difference ?
I mean writing as :
let b (length)
let a (angle)
if (b > 25mm)
{a=360deg +360deg/25mm*(b-25mm)}
and still , none of them have any affect on a , sorry I change the parameter from 'c' to 'a' ,
Create a length parameter called b and an angle parameter called a using the F(x) button.
copy paste this code into a rule.
/*Rule created by dbezaire 06/02/2014*/
let i_len (length)
let o_ang (angle)
let i (integer)
/* Inputs */
i_len = b
/* Evaluations */
if b > 25mm
o_ang = 360deg + 360deg/25mm * (b-25mm)
i = 3
/* use the bracket to add multi lines to if statement */
/* Oututs */
a = o_ang
A should = 432deg
Win XP64
Dell T7400 16GB Ram
y=r * sin(a/c*x)
and my parameters :
r : Length
c: Real
x : angle ( i tried both radian and degrees , no difference )
y : length
b: length , that is the guide curve of law : x axis
and my rule :
let b (length)
let a (angle)
if b > 1000mm
a=360deg +360deg/1000mm*(b-1000mm)
else if b == 1000mm
a=360deg
else if b < 1000mm
a=360deg + 360deg/1000mm*(b-1000mm)
this works for small amounts of b , there is a compromise between c and b , looks like !! when b is very big , like 1000 mm you can not select c big like 1/60 , you see that the function doesn't have actually a sinusoidal shape !!
my question is :
why ?????????????????????????????????????????
