Ckeck-Mate - how to control levels ?
Hello-
I have created a simple profile in Check Mate , used to check for if all sketches are fully constrained.
When I "execute" the profile , it works very well - both on toppart and components.
But when I execute the same profile from a toolbar "generated in Author Test" ,only the active workpart are checked.
Can the profiles *dfa. file be added some info to tell it to load and check in all level's of an assembly.
lklo
