To Purge the Assembly which is referenced
I am suppose to Purge the previous versions of a Assembly in I-deas tdm.
The latest version is 7.
When i try to purge , I a recieving an error message like "Assembly has dependent relationship" .
I gone through the cause of this error and finaly find the one user referenced this assembly and deleted the model file (mf1) in improper manner.
Now, is it possible to remove that dependency and purge the assembly.
RE: To Purge the Assembly which is referenced
My understanding Proper way is that we should Open I-deas ->File-> Delete -->CHoose the mf1 file need to be deleted.
I think this might be the reason (deleting directly from compute folder) might be the reason for that "Assembly has dependent relationship" error.
Is there any other possibilit for this error.?
Please help me to fix this issue and purge the assembly.
Lot of thanks in advance.
If you still can't purge the old assy version it may be used in another assembly or on a drawing.
If it still won't purge you might need to clean the database with dmadmin.
Mange Libraries->Highlight assy->Click MF Assoc report
There is an option to delete the relationship if necessary: (Delete Rel)
