Calling catserveng
Calling catserveng
Calling catserveng
Hello catserveng. Would you mind looking in on thread;
Connection winding salient pole of AC generator to rotating rectifier
In the
Circuit design Forum
And check my advice and add any comments you see fit.
Thanks.
Yours
Bill
Bill
"Why not the best?"
Jimmy Carter
RE: Calling catserveng
Hi Bill,
You walked him thru it very nicely, frankly if I see you are answering a thread I usually don't have much else to offer.
I had a couple of bad experiences using larger batteries to flash fields, in both cases I was not there directly but was trying to help someone from long distance, that's reason for the lantern battery comment.
Appreciate you valuing my opinion, regards,
Mike L.
Thanks Mike.
Bill
"Why not the best?"
Jimmy Carter
