Creating area from two different circles.
i want to create a cone. i have made two circles of different radius, now by joining lines through these two circles or some manner i want to create an area, can anybody help me how to do. since i want to control my mesh in a particular section i am doing in this way instead of using direct cone creation. here is the script file. pls help with this.
/CLEAR,NOSTART
/GRA,POWER
/PREP7
ET,1,SHELL93
R,1,0.00125,0.00125,0.00125,0.00125, ,
K,1,0,0,0
K,2,0,0,1
K,3,0,0,0.5
K,5,0.7,0,0.5
LSTR,1,2
LSTR,3,5
CIRCLE,1,0.35
CIRCLE,2,0.7
/CLEAR,NOSTART
/GRA,POWER
/PREP7
ET,1,SHELL93
K,1,0,0,0
K,2,0,0,1
K,3,0,0,0.5
K,5,0.7,0,0.5
LSTR,1,2
LSTR,3,5
CIRCLE,1,0.35
CIRCLE,2,0.7
RE: Creating area from two different circles.
Where is the section for which you want a specific meshing ?
I think the best way to draw your cone without the primitive creation would be to start drawing a line and then rotate it along the cone's axis. But it depends on the said section where you want your particular meshing.
Look up:
CON4
CONE
