Excel Solve - solve using list of numbers only
Hi All.
Great forum.
I am trying to write a spreadsheet to tell me a combination of available gears to put in a gear train given a desired gear ratio.
The setup will be a compound gear train. I will write a different program to try and solve for 3 gears, 4 gears (common lay shaft).
I am having trouble seeing how to constrain the input to a list in the sheet. I want to be able to select a single input cell (used as an input part of the formula)and constrain to a list of specific numbers (the gears I have available).
I seems to want me to select a single constraint for each input only.
This is in excel 2003 with solver add-in.
Thanks for any suggestions.
p.s. I found a similar question to this on this site but couldnt make sense of applying the constraints
RE: Excel Solve - solve using list of numbers only
Wrong approach. Even if Solver was good at integer stuff, I still think you'd be better off stepping through the tiny number of combinations and getting an exact answer.
Cheers
Greg Locock
