Datasheet preparation for integrated manifold double block and bleed valve
in a project were integrated DBB valves with 2 ball block valves and a needle bleed, is a special item. In preparing datasheet for vendor requisition, do I need to specify materials for various trim parts or should I only describe fluid properties and flow characteristics allow it to be by manufacturer's choice.
RE: Datasheet preparation for integrated manifold double block and bleed valve
- You need to specify materials for various trim parts.
prognosis: Lead or Lag
