HOW: closed surface into solid
Can someone explain me how in NX7.5, i can make a solid body when i have closed surface
e.g. : a cube with 6 sides all surfaces, how i turn it into solid body?
RE: HOW: closed surface into solid
Insert -> Combine -> Sew...
However, if what you've got is a 6-sided Sheet body that it not an actual Solid, you'll need to separate it into at least 2 separate Sheet bodies and then sew it back together which will then give you a Solid body. So, to do that, go to...
Insert -> Combine -> Unsew...
...and select anyone of the faces of the body and then hit OK. Now go back to workflow described above to Sew the Sheet bodies back into a Solid.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
