Analytical rigid surface revolve feature failed in Abaqus Scripting
Hi, I'm using Abaqus Scripting to make an impact model in my final degree proyect.
This is the first time working with Python and I'm having some problems.
I have to design a cylinder with the next features (3D and analytical rigid surface)and when I run the script in Abaqus I always receive this message "Analytical rigid surface revolve feature failed"
This is my code, and any help will well appreciated. Thank you.
from abaqus import *
from abaqusConstants import *
import regionToolset
session.viewports['Viewport: 1'].setValues(displayedObject=None)
#Create model
mdb.models.changeKey(fromName='Impact', toName='Impact')
shellModel = mdb.models['Impact']
#Create the shell
import sketch
import part
shellProfileSketch = shellModel.ConstrainedSketch(name='Shell CS Profile',sheetSize=5)
shellProfileSketch.rectangle(point1=(0,0), point2=(0.1,0.1))
shellPart=shellModel.Part(name='Placa',dimensionality=THREE_D, type=DEFORMABLE_BODY)
shellPart.BaseSolidExtrude(sketch=shellProfileSketch, depth=0.004)
#Create proyectil
import sketch
import part
proyectilProfileSketch = shellModel.ConstrainedSketch(name='Proyectil CS Profile',sheetSize=5)
proyectilProfileSketch.Line(point1=(0,0), point2=(0.0065,0))
proyectilProfileSketch.Line(point1=(0.0065,0), point2=(0.0065,0.025))
proyectilProfileSketch.Line(point1=(0.0065,0.025), point2=(0,0.025))
proyectilProfileSketch.Line(point1=(0,0.025), point2=(0,0))
proyectilPart=shellModel.Part(name='Proyectil', dimensionality=THREE_D, type=ANALYTIC_RIGID_SURFACE)
proyectilPart.AnalyticRigidSurfRevolve(sketch=proyectilProfileSketch)
#Create model
#Create the shell
import sketch
import part
#Create proyectil
import sketch
import part
