restoring condansate tank
dear all,
good day
we have faced a problem n our gas plant, when our fair team was doing a test to the hydrants over the tank.
the roof was fall of water over it , which cause skewed to the roof and that's lead the condensate to escape over the roof. Could any one explain or guess the reason??
even more we are going to restore the tank, have any one a scope of work should be done or any tasks should we consider??please send to us
many thanks for your cooperation in advance
good day
RE: restoring condansate tank
Is your question how the water/condensate got there, or why did the roof deflect, or adopt a "pitch" that was not there before?
I can see English is not your first language, so add photos and sketches as your explanation is difficult to understand, but it sounds like the roof has partially failed.
Were drains open? Were they adequately sized for the flow?
I will try to explain to you,
before one week, our operators saw that the condensate escaping from the roof and flooded out of the tank. when went up to check the roof the founded Slightly sloping. they thought that sloping because the drain of the tank was failed (plugged), it could be that happen?.
I have see a lot of corrosion on the internal wall of the tank, so is that corrosion cause that problem when the roof moving up and down??
I hope that is clear enough.
Who knows, you have provided no information, no drawings and no photos. Seems all the details you can, add a diagram and some photos and ask some particular questions. Remember we can't see anything from here so can't see the size, the damage, the vapour pressure of the liquid, the corrosion, the inlet and outlet flowrate etc etc
thank you very much for you kind reply. you find attached the failure report for that tank an a pictures for it.
this report I think is quit poor and not enough, what do you think??
please check the attachment.
thank you in advance for your help
Your issue now is that the roof has sunk without being prepared properly by having all it's legs down. This could lead to internal damage to the roof, especially the pontoons or any internal pipework and also maybe the seals if the roof has gone down too far.
What you need to do is pump out all the water on top of the roof, add water slowly to the tank to re-flaot the roof, put all the legs down, drain the tank again and get inside and inspect it. You might have damaged the pontoons under the roof, but otherwise it looks in good condition from the photos supplied.
I'm not sure why your operator allowed the fire pumps to continue spraying water into the tank for any longer than 5 minutes without someone going to see if there actually was a fire. most fire and gas systems I see now work on the basis of not actually doing anything until it gets "confirmed fire", either two sensors going off or a manual push from someone with eyes. Maybe need to think about how your system responds to fire warnings in in the future.
I am really thank you very much.
I would like to notify you that the internal wall (shell ) of the tank is really corroded.
this also I think strong reason to damage the seal and one of the reasons to this problem??
I can't see it being a big problem for the seals, but again you need the seal vendor to come and inspect it if you think they need repairing or replacing
I am really appreciate your help
many thanks
The biggest question is whether the pontoons under the roof are full of water or air - they need to be full of air otherwise your roof will never float again. You're going to need to remove all those manholes on the outer rim of the tank and pump the water out (if any).
the pontoons are fall of water as you can see in photos.
so we need to pump out the water?
