Hardness Test
Hardness Test
Hello All,
i'm quite new in welding issue.
Currently i'm trying to do hardness test without destructing the parts. Hardness at 3 zones need to be verified ( weld zone, HAZ and base material)
Can you suggest the best way and what machine shall i use to check the hardness?
Thank you in advance.
RE: Hardness Test
www.casteelnoble.com/poldi.html
For thinner materials:
www.equotip.com
RE: Hardness Test
RE: Hardness Test
Appreciate if you guys can share more tips for newbie like me.
RE: Hardness Test
RE: Hardness Test
The advantages of the 2 systems I mentioned are they are both portable and both widely recognized hardness test equipment.
I concur with metengr, you need qualified procedures and personnel..
RE: Hardness Test
RE: Hardness Test
Both Rockwell and Vickeers will leave macro surface indentations. Equotip (or some similar comparable equipment) should suit.
Have you no traveler or quality documents which control which method should be used?
RE: Hardness Test
Since I'm in middle of doing feasible study on hardness test,I prefer to go details.
Document did give some recommendation on what to use however I want to know details.and which are the best method.
Thanks for all suggestions☺
RE: Hardness Test
All require a decent surface finish anyway for example polished the surface with a portable grinder/flapper - I'd recommend King Brinell. Also depends what it is your testing?
RE: Hardness Test
RE: Hardness Test
Brett Linzer / www.CheckLine.com
