Source of special symbols
I am trying to reconstruct some diagrams from the 1960s.
I am trying to insert special characters - y diaeresis (U+0021), x diaeresis and z diaeresis. I have found U=0021 but cannot find a code for x or z. Some guidance would be greatly appreciated. David >74 yrs young.
RE: Source of special symbols
I found ẍ (U+1E8D) and Ẍ (U+1E8C) but not z with diaeresis or Z with diaeresis.
Actually I created my own work-around - I am creating some small dwgs in DraftSight - by putting 'x' on one layer and '..' on another layer, suitably positioned.
Type "bmake", or you can get to it through the menus, though I don't recall exactly how. You pick the objects you want in the block, then you have to pick an insertion point. When you need it, you just insert the block.
from Ginge Down Under
