Maintenance/Operation of ACSS Conductors
Does anyone have any experience using "hot-stickable" connectors for ACSS conductor? Generally you are required to use compression connectors for ACSS, but that significantly limits your ability to operate and maintain a line.
For example, you have a tap structure off of a ACSS line with a air switch on either side. If you want to perform maintenance on either switch, you must take the tap (and subsequent substation) down. Is there any connector out there for ACSS that is removable with a hot-stick so you could remove jumpers on one side of the tap structure to keep the sub operating?
RE: Maintenance/Operation of ACSS Conductors
I'm not 100% sure what you mean by stirrups, but I Googled it and couldn't find anything for ACSS. How do you use stirrups for non-ACSS conductors?
