Sandblasting Valves
Sandblasting Valves
Hi, for sandblasting (Air pressure 6 bar), what types of valves are recommended?
Thanks!
Thanks!
RE: Sandblasting Valves
Corrosion resistant, exotic alloy valves from The Alloy Valve Stockist in Barcelona, Spain http://www.gate-valves.com
Hi hsbcn,
the second: what type of valves to use in a sandblasting machine/system?
thanks,
Edward Q.
I have no experience, but could mention that at one of Europes (at that time) largest steel foundries, a sandblasting holding booth for cleanblasting casted steel objects gave problems with very fast detoriation and excessive wear of the booths steel walls. Solution: walls clad /protected with rubber.
(Soft sealing NBR or EPDM clad valves if suitable? Pinching valve?)
Thanks, I'm going to test with a pinch valve. I will tell you later about it.
Edward Q.
Not introducing sand until you absolutely have to would also seem like a good idea...
airsmybag
