OBJ import for Solidworks
Does anyone have any experience with the OBJ file importer for Solidworks by Sycode?
http://www.sycode.com/products/obj_import_sw/
I'm trying to find a way for SW to open OBJ files and I just came across this translator...
but would like to know if others have any positive results with it?
Thanks very much
RE: OBJ import for Solidworks
I have never used it, but I am sure the faces when imported in look like the image shows "triangular/quad faces". Which could make for some serious complex files or Surface files if there is a hole in polygons.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
