2d sketch on a drawing
I need to 2d sketch on a drawing (drafting) sheet and constrain it to the view elements and add some dimensions. How could I do it?
The idea is to show sliding distance of a CAM in the drawing.
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V8.5 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
RE: 2d sketch on a drawing
John, I had tried "Sketch on Sheet..". But couldn't constrain the way I requested. when the view moves, I want the sketch to move with the view.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Don't use any views, just treat the Drawing sheet as one big sketch view, like I did in the example Drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry I may have not clear enough. I agree, I could add constrains inside the sketch but not to an existing view’s elements.
I've a cross section view and I want to show cam operation/timing diagram. i.e. the distances of driver movement, cam/punch movement, die movement etc. and show parametrically the resultant value. For this, my Sketch on Sheet should follow and align (add constrains) to the view’s elements.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Thanks to GTAC support I got the answer.
RBM the view and select "Active Sketch View" and start sketching. Then could add constrains to the view model geometry and to the new sketch.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Thanks for the updating everybody Michael
You are welcome Jerry. (I believe, to receive I've to give)
If you like you could also give stars to highlight for others to look at the thread.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
