HVAC Climatic Design
Can someone define “coincident 1% outdoor ambient dry-bulb temperature”? Thank you!
RE: HVAC Climatic Design
>>co·in·ci·dent adjective \-sə-dənt, -ˌdent\
>>: happening at the same time
>>Full Definition of COINCIDENT
>>: of similar nature : harmonious <a theory coincident with the facts>
>>: occupying the same space or time <coincident events>
I was not sure if 1% means that the design temperature has been exceeded only 1% of the time during the year or the design temperature occurs only 1% of the time during the year. However, I think that my first assumption is correct. Please let me know if I am wrong. Thanks!
If you use 1%, 99%, 99.6% is up to what you want or the owner wants, or code prescribes. Code also may prescribe something in addition. Here in WI the ASHRAE recommendation is -11°F (based on 1% i believe), code requires -15°F... so following the percentile rule is moot since you need to meet code.
Used for the design of evaporative coolers or dehumidification equipment.
