Create new part in Assembly
Hi Guys,
I am working with assembly and want to create new part inside the assembly. that new part will be made through projecting curve from the another part in assembly.
After I create that new part, please advise how will I be able to save it as a separate model.
I hope it make sense.
Thank you
regards
Rodney
Thank you
regards
Rodney
RE: Create new part in Assembly
If you're modeling within the assembly (not within the existing part), just use Project Curve and create your model geometry, then use "Create Component" within the 'Assemblies' application toolbar. Just select any geometry you want to be included in your new part and give it a name/number. Done.
Hope this answers your question.
Rhys
If I was to make new part within the existing part using project curve, what will be the possible way to create new part as a separate model without removing its parameters ?
Thank you
Rodney
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
