Thermo chemical cleaning .
We are tyring to clean surface oxides from nickel nased superalloys using thermochemical cleaning ovens using cf4.
We are struggling to remove fully the oxide films using a 1000c fro 1 hour cycle . Any ideas?
RE: Thermo chemical cleaning .
no water just hydrogen and cf4 and argon purge,
the parts are coming off wing and the cracked aerofoils are littered with okide clusters on the surface of the cracks
The best cleaning practices are probably abrasive, followed by chemical. The abrasive loosens/detaches/erodes a high % of the contaminates; then the agressive [highly dangerous acids] can be used. But this would be my best guess.
This materials cleaning problem is best suited for the materials "other" forum... Suggest posting your question there: http://www.eng-tips.com/threadminder.cfm?pid=367
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
