Expansion analyses in flexible pipes
Hi everybody,
Has anyone made an expansion analyses on flexible pipes? Is the poisson' effect taken into account in the analyses? How the temperature induced axial elongation influence the expansion?
Thanks in advance,
Vanessa
Thanks in advance,
Vanessa
RE: Expansion analyses in flexible pipes
What type of "flexible" pipe are we talking about here?
Poissons effect is for solid materials.
I don't really know what 'expansion analysis' means in this case though. I would have thought it was an analysis of axial thermal expansion/stress if not for the third sentence.
Stress analysis is common practice in the piping and pipeline world, especially if significant temperature differences are anticipated. For steel and similar solid materials poisons effect is used in the design or operating scenario.
Clay and concrete are still flexible, but less so than the others you mention.
I think you should dig out your Strength of Materials text book and read up a bit on what Poisson’s Ratio and the Coefficient of Linear Expansion are, and may have in common, or don’t have in common. Then rephrase your question, with some specifics and details, so we don’t have to guess what you mean or what you want help with.
My question is related to the global behavior of the pipe when it is laid on seabed and it is subjected to pressure and temperature.
Since the pressure armour layer (internal layer) is the one that has the funtion to resist to the hoop stress and bending, and the tensil armour layers the one that resists to the internal pressure and axial tensions, I need to simulate the global behavior of the system.
Please answer only those who have experience in the specific field.
Thank you
Vanessa
Hence you need to get this information from your particular flexible pipe vendor, which may require some lab type tests if not available.
In general because the layers are mainly filament / thin strip winding type, the thermal expansion is reduced and there is no poissons effect as there is no solid material tube on which this effect can occur.
The tensile armour layer has little impact on the internal pressure due to the longitudinal nature of the filaments, normally at some 30 degrees to the axial length, similarly the hoop stress filaments are at nearly 90 degrees to the axial direction and have virtually no impact on axial strength, bending or expansion force.
Application of pressure, especially sudden pressure increase, will have an effect on the pipe, but you need vendor data to try and see if you can simulate this or not.
also, I would take issue with the definition of flexible proposed by little inch, depending on the particular usage for pipe, steel pipe is generally considered to be flexible for engineering analysis purposes, however much less flexible than say PE.
https://www.google.com/search?q=is+steel+pipe+cons...
If you want "only those who have experience in the specific field" to respond, you need to very clearly indicate what that field is and EXACTLY what the question is, we're not all psychic here. Your original post didn't say if you were sticking PVC pipe in your attic, designing swingsets, running pipelines across the Sahara, or what. You might also consider if the question is best referred to the Structural forum or, say, the "Pipelines, Piping and Fluid Mechanics engineering" forum.
I also thought that too.
But I've read articles that say conflicting concepts.
Upheaval buckling behaviour of flexible flolines, ISOPE 1995,
Flexible pipe on-seabed stability, upheaval buckling and hub protection method, ISOPE 2013
Anyway, If no data will be available by the vendor, I'm going to neglect the Poisson effect ( as claimed in the second article) and I'm going to consider the same coefficient for termal expansion as for rigid pipe ( as per the first article).
