Assemblies -> Arrangments - Necessary Settings?
I am creating four different arrangements for a large assembly.
Since i am moving some of the parts , i used to set the following parameters before moving. But i really dont know , all of them is strictly necessary.
1. Right click on component -> PArameters -> Individually positioned arrangment section.
2. Right click on component -> Override position.
3. While moving , Settings ->arrangments -> Apply to used.
My question is whether all of the above is necessary to move a component in different arrangements or any one of them is sufficient.
RE: Assemblies -> Arrangments - Necessary Settings?
Well, the only time that you need to use the 'Override Position' is when you're moving Components at the top Assembly level which are in a Sub-Assembly.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Quote ("Components at the top Assembly level which are in a Sub-Assembly")
Little bit confusing. But i understand it is not necessary.
Is it possible to explain the option "Apply to Used" in move components tool. What does it mean actually.
When you move a Component, this is how you save that new position in the current Arrangement being "used".
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
