Link fix-up tool to replace parts
Hello experts,
Is it possible to replace parts in assemblies by Link fix-up tool in SE ST5 for unmanaged data?
I am tired to use Rev Manager to redefine links for each element since it takes to much time...
Following poor SE help, I've tried to analyse assy folder by "analyze" tool which produce xlsx file with file paths.
Next manually modify this file by add new file paths for column C and D. Then apply modified excel file to "link fix-up" tool for unmanaged spreadsheet...Process finished! Nothing happened?
Is this tool supports redefining file paths or other?
Thank you.
