HYDROTEST,CHARPY and other TESTS Acording ASME..........
HYDROTEST,CHARPY and other TESTS,
Are these tests mandatory for each pipe length acording to ASME ?????
RE: HYDROTEST,CHARPY and other TESTS Acording ASME..........
But as Testing procedures we required to be acording ASME...
I dont want to be anywhere near you(r plant).
API 5L X60M is an USA standart of material so to be tested with ASME and from EN we took the loads to calculate knowing that EN and ASME have their equivalent grades of steel.
but my answer was which tests are mandatory for each pipe length acording ASME.
Anyway thank you.
Anyway, mixing up codes, which is what I understand from your post, is not a good thing.
a) What is your design code?
That code will dictate the testing requirements. In general, leak testing (i.e. hydrotest) is mandatory. Charpy testing only when your design code tells you to. Charpy can be done on weld material, base material or both. And it can also be a welding procedure requirement.
b) Does CE marking apply? I.e. PED 97/23/EC
Answer both a and b and we may be of help.
