dimension ID's on drawing
I'm setting up drawing standards and think I will have utility for attaching a dimension ID to each drawing on a print. By this I mean literally every dimension on the drawing will have an ID number. I have several downstream reasons for this, but the underlying principle is that if it is worth putting on a drawing, it is worth giving it an ID other than "that dimension in Zone B6 that is 1.4... I mean 1.41".
Has anyone had experience with such a system? Thoughts in general?
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/_chrisloughnane
RE: dimension ID's on drawing
SolidWorks does this automatically. Your CAD probably does too. If you need an ID, is there any reason you would not use your CAD's?
JHG
My understanding is that if I delete dimension "X" and add dimenson "Y" that the SolidWorks-assigned dimension ID for dimension "Y" will be the same as the one for dimension "X". This would have negative implications for traceability.
Perhaps I am missing some functionality?
I get doing it on an inspection print, maybe even have it as a layer/setting (or whatever term your CAD uses) that QA can turn on when they generate their copy but is by default off.
However, having it on the body of the Engineering drawing rubs me the wrong way - but like I say I don't think I can quote chapter and verse to say why I think it's wrong.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I personally hate it, makes a huge mess of the drawing.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
In practice: Almost certain to be a disaster.
Haven't seen anything like this in 30 years.
loughnane, how unique is your situation, to justify approach completely foreign for most of the world?
And about Solidworks:
If you "delete dimension "X" and add dimension "Y" ", it actually calls for drawing revision. So, in rev.B Dim37 equals 1.41, in rev.C Dim21 equals 1.41. Isn't it still traceable?
Pardon me while I stand up on my soap box...
Dimensions are about as fundamental a building block as you can get in mechanical engineering, and yet our default way of doing things is to reference "that 1.45 dimension in zone B2" which may change (both value and zone) in subsequent revisions, meaning that there is no persistent identifier throughout the life of the part. This ambiguity makes inspection, analysis, and traceability a very manual process.
Imagine the value of having an ID for every dimension on a drawing. Now also imagine that you build an exhaustive mathematical model (tolerance analysis) of your assembly. While you are in production you will inspect the few critical dimensions every so often, and on a less regular basis you will do occasional inspections of everything. Because each of the inspections is explicitly tied to an ID, you will be able to automatically pipe the inspection data into your mathematical model to see what dimensions are changing, what correlations between dimensions are changing, what tolerance stacks are shifting, etc.
So putting dims on every drawing is a pain, but it really could empower small hardware companies to do things much more efficiently.
I doubt it, because small hardware companies probably aren't going to have to resource to do all the other things involved in your ideal process.
The good news is, surfaces are uniquely identified in CAD models. The bad news is, relating them to the dimensions and tolerances that govern them is not readily available.
1. It is easier for us to put these inspection balloons on the print vs quality. Quality would have done this with a circle template and a pencil.
2. When we get a Quality report from the supplier the dimensions numbers from the supplier and our quality match up.
It works well for us. But I question what is a dimension. We only ID the feature of sizes and FCF frames. We do not ID the basic dimesnions. There are some other rules we use but every once in awhile we run into an issue with 2X or should this dimension get one or not.
I don't actually see any value beyond the inspection process. Pumping QC data back into your stackup does not actually change your tolerance analysis.
Use SW how it's designed to be used, and dim drawings so others can understand them.
Making them unique so YOU understand them, more room for errors and higher costs.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
After some research, we purchased a software product called Inspection Xpert.
We purchased their PDF compatible version, as the inspection department didnt have solidworks access and all of our customer prints were PDF format.
They do however have a version that supposedly integrates into SW, but I have no experience with it.
I thought overall it was a very nice program.
It made it simple to balloon and create inspection plans and it was easy to update or change when needed.
I liked the "grouping" so you could group a bunch of basic dims to their respective FCF.
I liked it because you can add custom fields, so we would have our programmers go in and for each dimension list what tool(s) was controlling the feature so that we could map our inspection plans to the process critical features.
It was a relatively affordable product IIRC.
We had one floating license, which is fine if your workflow is sequential, but for parallel processing this can be a little tedious.
I didnt post a link to the software because I didnt want this post to come across "spammy" but you can google it.
