DIRT ROAD MAINT.
DIRT ROAD MAINT.
WHAT ARE THE BEST WAYS OF GRADING DIRT ROADS TO
REDUCE WASH BOARD BUMPS AND REMOVAL OF ROCKS
WHAT IS THE BEST WAY TO SMOOTH A DIRT ROAD WITH THE ABOVE
PROBLEMS.
PROBLEMS.
RE: DIRT ROAD MAINT.
If you have a road that is poorly drained, you may need to make changes to your grade and install culverts or other cross-drains to channel your surface water. Water on the road can be diverted toward the sides by shaping the surface to a crown. If the road edges are shaped to a ditch, the natural slope should channel drainage. If you have a low point that won't drain on one side, you may install a culvert so that the drainage doesn't flood the road and erode a channel through it. If your low point has slopes on both sides, that gets a little more in-depth.
Most shaping work I see is planned using Autocad, and there may be preset models that just need fine-tuning.
