Inlet piping for factory installation
Afternoon All,
My company has tasked me with organising a very simple inlet piping system.
I believe it falls into CAT D
It is literally 3Bar mains water feed supplying a positive displacement pump.
max flow 13.5 l/min
The system will be a permanent indoor fixture.
my question is can I use PVCu Solvent weld pipe?
It's well within flow, pressure and temp rating.
I only ask in case there is some directive I haven't found that specifies what piping should be used.
Any opinion is welcome.
Thanks in advance.
max flow 13.5 l/min
Thanks in advance.
